> P D Wrote:
> > live ɘvil Wrote:
> > > P D Wrote:
> > > I have never had a problem and I'm sure that I've trapped more than
> > just
> > > a bit of 'moisture' inside the bead .
> > > The only difference is water will take a bit longer to dissipate ,
> but
> > > t it does .
> > > Just for something to think about : why do a lot of shops slop soapy
> > > water around a rim & tire when mounting ?
> > > They keep a bottle and rim mop attached to the changing machine .
> > > Anyway , like I said , I'll keep doing what presents no problems and
> > > works for me . ;)
> > Ummm, I worked in more than one shop using a tire changer.
> > Shops typically dont use "soap and water" unless someone forgets to
> > order more tire bead lube. The bead lube is much slicker than any soap
> > and does not promote rust or corrosion.
> > Google it, many brands available.
> I'm sure that every shop uses bead lube , right ?
> I wonder what they used before bead lube was invented ?
> Not all shops are created equal .
> Anyway , good you got your hands dirty . ;)
Prolly astroglide.
