Re: How long to soak a carburetor in a can of gunk?
Josiah Radebaugh /
I'd do over night.
What I do to clean carbs is: Use any thing to clean the exterior that will break up oil and what not. Take off the bowl, float and needle, jet.. I just use really hot water and pleanty of dawn. After that, use an air compressor to blow everything thing out, try to blow air the opposite direction of normal flow so you don't lodge anything deeper. (edited)
