Low Compression - Help
Alex Yampolskiy /
So all of a sudden my Puch wouldn't start and after doing all the tests (fuel, spark, compression) I found out that it has very low compression and wouldn't turn over.
I replaced the piston rings and gaskets, however it didn't help and the compression is below 20psi. It did start once when I was pedaling really fast and "dropped" the clutch.
Am I missing something? Is it due for a full rebuild? When I replaced the rings, I did NOT hone the cylinder. Not sure if that's an issue as well.
Really appreciate any help.
Re: Low Compression - Help
What kinda compression tester are you using?
If it was still low after changing rings your comp tester is no bueno.
Did you try cleaning your carb?
> and the
> When I replaced
> well.
>" Wouldn't turn over" means that the piston would not go up and down. Did you mean that the engine wouldn't fire?
Using the same compression tester, test compression on another machine to see if the tester is accurate.
Yes, not honing was a mistake.
Alex Yampolskiy /
Didn't try cleaning the carb, although it is probably due for one. The comp tester is from Amazon. I also tried covering the spark plug hole w/ my finger and the compression is still super low
Alex Yampolskiy /
Hmm wonder if it's the seals and the whole engine is due for a rebuild...
Is it a push in or thread in tester? Are you testing the compression with the throttle wide open?
Alex Yampolskiy /
Thread in tester and am keeping the throttle wide open.
this is the tester
https://www.amazon.com/dp/B01NAGRKJ4/
