rig up petcock suggestions
up shits creek /
the pet on my free spirit came without a lever to turn it on/off/reserve. currently using a plyers and it's kinda annoying. eventually i'll get it replaced.
the hole doesn't go thru. wondering how I could rig up something to work till i get it replaced.
possibly drill thru. use a bolt n nut or maybe dowel/nail(think axe style), could try some epoxy and not drill thru.
open to suggestions.
thanks
Re: rig up petcock suggestions
Dirty30 Dillon /
Just put a machine screw in there...
up shits creek /
hmm. good call. i'll give it a shot
Yeah, those holes are threaded, so find something to screw in the hole.
up shits creek /
It'll work for now! Thanks MA!
Seeing as the petcock could perhaps save you from peril if you get a profuse fuel leak onto a hot motor you may want to consider purchasing a replacement rather than screwing around with a crapped out original. It not an expensive item.
up shits creek /
Def on my next treats order. This is a stop gap and better than carrying around a plyers
Or a fire extinguisher. Best to change it,asap.
