Nope, milk is a whole different tank, single chamber, which doesnt help with the slosh unlike oil tankers which are multi chambered to prevent it.
Milk tankers are sanitized with extremely hot water after every load and sealed with seals that have matching serial numbers, if the load has mis matched serial numbers it is rejected and a 15k truck load will only be worth about 3k.
I work in the milk industry.
Some tanks are even blessed by Rabbis so they can be Kosher! Imagine that!
> live ɘvil Wrote:
> > ♣Slew Foot♣ Wrote:
> > All right most people don't know this but those tankers that carry the
> > gas in bulk all have three grades of gas in them and when they wash
> out
> > the trucks they use lime some of it gets dissolved in the gas in the
> > next batch what happens is when ethanol gets involved it holds it in
> > suspension and when it settles out you'll get this white crummy stuff
> > that just fills the carb it's a crystalline growth that there is the
> > start of it the best way to clean that crappy metal is the strongest
> > vinegar you can find usually that would be 7% you leave it in there
> > overnight if you have one of them ultrasonic vibrator things all the
> > better after 24 hours wash it out with warm water and a little baking
> > soda then rinse dry blow out with compressed air
> Why would they wash out a petroleum tanker? To haul milk in it?
