No Spark help
Hawthorne Swan-Scott /
So I am finishing a Puch Newport but I am not getting a spark from the plug, I have tried buying a new spark plug but still nothing, the light and horn both work when I try to kick it over but no spark any ideas??
Re: No Spark help
i stick to 70s hondas but most of the bikes i buy need a new spark plug boot so check that
Re: No Spark help
Check the boot to ensure it’s tightened on the lead and actually making contact with the wire inside, check that the lead is tightened onto the coil.
Re: No Spark help
Check the points and replace if needed and replace the condenser too. Are you getting any thing from the coil? If not then points/condenser
Re: No Spark help
So in my efforts to find what is wrong with the spark, I have found that I am getting like 6 plus volts from the ignition coil while I pedal it connecting a multimeter to ground and inside the spark plug boot. If that helps with anything
Re: No Spark help
Chris Carleton /
Stick a nail file between points and give it a few strokes should do it.
Want to reply to this thread?
