Piaggio Ciao - Gear oil refill
Morten Schubert /
Hi all
Does anyone know how much gear oil I am supposed to fill in the rear hub of my Piaggio Ciao? It's from around 1974.
I'm assuming the hub isn't supposed to be completely filled with gear oil, as the refilling hole in the hub is located at the bottom of the hub. Am I correct to assume that I should simply fill it until it starts coming out of the refilling hole in the hub?
Cheers.
