Piaggio Ciao - Gear oil refill
Morten Schubert /
Hi all
Does anyone know how much gear oil I am supposed to fill in the rear hub of my Piaggio Ciao? It's from around 1974.
I'm assuming the hub isn't supposed to be completely filled with gear oil, as the refilling hole in the hub is located at the bottom of the hub. Am I correct to assume that I should simply fill it until it starts coming out of the refilling hole in the hub?
Cheers.
Re: Piaggio Ciao - Gear oil refill
Yes sir, that's it.
Morten Schubert /
Cheers, appreciate the quick answer!
Richard Eberline /
That other hole is the vent.
Morten Schubert /
Not sure what other hole you are referring to?
In the image below, I've marked the refill hole. The other two holes are for mounting the rear hub.
Want to reply to this thread?
