pa50 variator
what does it do, how, and where can i get one cheap
Re: pa50 variator
No such thing as cheap with these....
Re: pa50 variator
It's the transmission for the Hobbit. It uses the centrifugal force from the engine RPM's to change the gear ratio applied to the rear wheel. Do you just need a variator or the entire clutch assembly?
Re: pa50 variator
the clutch is there the belt is spinning on where the variator should be
I have an elite 150 im parting out that one won't fit, right?
Re: pa50 variator
also what physically happens to do this?
