Puch maxi, dim/weak lights..
78' maxi luxe.
Previous owner wired it so the headlamp/taillight are always running.
No break lights
No speedo light
No horn/light switch
While tinkering, I detached the headlamp and all of a sudden my taillight is bright at idle, just like my other peds. But as soon as I hook the headlamp back up, the taillight goes back to a barely noticeable glow.
All of the other wires that are no longer in use are just free hanging, not touching.
I'm just wondering to why I barely have any bright lights at idle, and what could cause this.. And no, it doesn't get any brighter when I throttle it..
Re: Puch maxi, dim/weak lights..
Sounds like someone has jumpered the headlight to the tail light circuit. You cant do that because each lighting coil is only designed to sustain its respective bulbs/circuits. You're gonna have to dive in and go over all the wiring using that schematic above^ to figure out what p.o. hacked.
Want to reply to this thread?
