1971 Vespa Ciao Will Not Start
Colt Hadley /
I have a 1971 Vespa ciao, it had been sitting for 2-3 years I replaced the throttle cable, and put a 13.13 carb with Malossi intake on and did a 53 jet and I can pedal it and it sounds like it wants to start but will not take off, replaced spark plug as well and doing the same thing. Prior to attempting to start I did drain and clean the gas as well. Might try towing it later and see if it will kick off
