Re: 1971 Vespa Ciao Will Not Start
Seth B /
Promo circuit. Important detail, You’re probably jetted too low then. Also, check your compression. Sounds like maybe your decomp is maybe leaking causing low compression. Either way, stick with the basics. Fuel, air, spark, compression.
