> Trevor Fladwood Wrote:
> Working on an e50 clutch and having a strange issue. I was trying to
> adjust the spring tension to avoid grabbing too early, and I noticed
> when I move the clutch by hand, the bell is moving as well, just a bit
> when I move the clutch forward but continuously when I move the clutch
> backwards. (I guess I’ll remember not to ride backwards). The bushing
> seems fine and the bell moves well on the crankshaft. I tried a couple
> of clutches and got the same result. Could this be a shimming problem?
> Anything else I check?
> Thanks!
Any chance you have a dmp crank ? Mine needed me to reduce he rear shim 1mm. But don’t forget you need to add it to the inside bell shim to retain correct pressure plate to clutch distance.
