> Drake Abrahamsson Wrote:
> It’s timed at 15* BTDC checked with a timing light. I set the point gap
> at .017” with feeler gauge however the flywheel was blocking it at TDC
> so I had to bend it all funky so I wouldn’t be completely surprised if
> the gap was greater than .017”. Could that be it?
When setting the point gap you want the flywheel to be a little past TDC, 15 degrees or so. Also, what's your oil ratio? And do you know what your compression/squish is?
