> Chris Straub Wrote:
> > Drake Abrahamsson Wrote:
> > It’s timed at 15* BTDC checked with a timing light. I set the point
> gap
> > at .017” with feeler gauge however the flywheel was blocking it at TDC
> > so I had to bend it all funky so I wouldn’t be completely surprised if
> > the gap was greater than .017”. Could that be it?
> When setting the point gap you want the flywheel to be a little past
> TDC, 15 degrees or so. Also, what's your oil ratio? And do you know
> what your compression/squish is?
Yes^
So many variables.
Too much oil and different types can cause build up while being hot. Are you running a temp guage???
Do so if not.
That color looks more like rust than chocolate. Pics of inside of fuel tank are in order here. (edited)
