> Drake Abrahamsson Wrote:
> What about my timing? I was at 15deg BTDC at idle RPMs. When I opened
> the throttle the reading started to go everywhere but I just blamed that
> on my cheap harbor freight timing light. Is this an issue?
> Also, I mentioned it before but my gap might be larger than the intended
> .017” because I had to bend the feeler gauge to get behind the flywheel
> at TDC. The somebody said I shouldn’t even be setting my points gap at
> TDC. If not, where do I set it?? The video TravisTutorial put up had him
> & his roommate setting the gap at TDC. Is there another certain degree I
> should set my gap at? And could a too large gap be the cause of this
> overheating?
Sounds like you got points jump,
Your point cam on the flywheel need to be perfectly smooth and lubed, your points at pivot need to move freely yet not be to loose or they will have to be replaced
if your points are jumping around all over the place at hi rpm/at speed that could be a cause of overheating, you got to detail all that stuff out to have your timing mark/line stay stable at speed
