> Ryan Graeme Wrote:
> Search "Oxalic Acid". I think it was PD that did a write up on it when
> he did some bits on his Simplex (I might be wrong, I might be making it
> up completely, but I remember Oxalic Acid looks the shit at cleaning).
Well, I did a week of Vinegar rinses, then a good neutralization with baking soda. I ran a lot of water through and got out a piece of petcock and Puch Cap measuring cup. Now I'm doing a day of Evaporust. I'm planning on dumping the evaporust and then drying as best possible, then adding a full gallon of cheap motor oil to coat the surfaces and stop any rust.
Last I plan to drain the oil and then follow up with a bottle of Marvel Mystery oil that will be sloshed as best I can. Finally a slosh 6 oz of gas oil mix. Drain and hopefully off to the races. If it comes back, I will repeat but try a coating.
