> ♣Slew Foot♣ Wrote:
> I would double check your flywheel hold the clutch or the back wheel and
> just move the flywheel back and forth and see if it has any play I have
> a feeling that your woodrift PIN has a Groove in there and that your
> timing is moving cuz I had a Tomas where the whole inner section of the
> flywheel was loose and it would only move like a millimeter each way so
> it always stayed within acceptable timing and never created a serious
> problem for two years and then all the sudden it was a serious problem
Hmm will do, I just put in a new crankshaft. I did notice that the woodruff keys on both side are the same & I'm pretty positive they're supposed to be different so I may just go ahead and buy new ones for both side just to set it straight once and for all.
