New here.
Pete Vanderberry /
Hey guys,
So I got a 78 puch newport as a project and have it back together and running. However, my only complaint is a weak horn. Which I need here in Vermont as I have to have it inspected, if anyone has any suggestions I'd greatly appreciate it
Re: New here.
When you rev the engine up while the bike is on the center stand, the horn should get a little louder. It's going to be weak at idle just like the lights are dimmer because it's powered off a coil and the magneto rather than a battery. Maybe you can explain that during the inspection? "It's louder when I need it to be"
Re: New here.
Pete Vanderberry /
Hi Mike,
Thanks for the reply. Even at a higher rpm it's still pretty weak. I may just put a squeeze horn on it for inspection, but its something I'd like to figure out down the road. I've worked on Vespas and chinese bikes before, but this is a whole different animal
Re: New here.
Yeah Puch actually did make a branded squeeze horn to mount on the handle bars. I wonder if it's because they just never could get the 6v horn system to be loud enough.
Re: New here.
That's something like I told my girlfriend " it's bigger when I need it to be". Sorry, my bad! ;)
Re: New here.
Drake Abrahamsson /
I mean I couldn’t help you with wiring or anything but I just did a quick “12v horn” search on treatland and found a few
https://www.treatland.tv/SearchResults.asp?Search=12v+horn
I think the horn is part of the ignition system electricity wise so I’m not sure how you’d figure that wiring out but maybe this is the start of a solution?
Re: New here.
I mean technically you could hide a charged 12v Lithium Ion battery like under the seat or side covers, and wire the horn and horn button to that. Just for the test.
