I hear you guys, i’m not
home right now so I can’t take shots. I used motoseal... It’s the stuff you use to seal E50 case halves together same stuff as yamabond etc.
I can assure you it’s a tight putter seal.
I changed the seal to a lightly used spare I had yesterday, it made a slight difference but a leak appeared this morning.
I’m awaiting the seal that is 1mm smaller in hopes I don’t have to crack cases again.
If I do, i’ll probably just get the cheap needle crank from treats everyone loves.
I’ve had the Rito before, but can’t justify spending that on a bike i’m trying to keep stock.
