Hobbit - stuck emulsion tube.
I can not remove the emulsion tube on one of my PA50’s. I have tried the bent coat hanger method and also giving it a good rap and still no avail.
Does anyone have any other method to try?
Thanks Jack
Re: Hobbit - stuck emulsion tube.
Maybe a screw and pry ?
why are you trying to? to drill it out? I dunno man, never had a cause to remove it.
Jessie Paull /
Mine was stuck when I took the carb out to clean. Had to soak it over night in carb cleaner, then it popped right out with a coat hanger
I picked up an abandoned Hobbit and was trying to clean the carburetor and the emulsion tube. Jack
