Daniel is talking about the little pin inside the carb body that coincides with the groove in the slide, to keep the slide located in the proper direction, so that the idle screw only raises or lowers the slide. If the slide is positioned properly, that damage won’t happen.
Re: wheel spinning scarily fast during idle? puch maxi
