> noah wingren Wrote:
> nvm, went to the basement and checked. it had slid out of the way, but
> was still there. pushed it back in with a key. i wonder why thats a
> movable part in the first place?
It should be 'set' in place . If you can pull it out , spray the hole and pin with brake cleaner . Then after everything dries , apply a bit of red loctite and reinstall it . That should help hold it where it's suppose to be .
