> live ɘvil Wrote:
> > George J Wrote:
> > So I removed the brake light bulb,wheni apply the brake lever she
> > doesn't stall. With the bulb in, she stalls when brake lever applied.
> > Front or rear. Diagnosing lectrical problems is not my strong point.
> Did you extract the blue wire from control pod on bars like I mentioned
> above^? If so, that would be the reason. The commuter is wired
> differently than most others. Put it back and tee into blue for
> grounding to bars to kill motor until you can repair kill switch.
I haven't yet but I'm going to do it now. The blue wire goes to the throttle side.Biu when i pull on either brake the motor cuts out.
