Re: Can't shut her off.
George J /
> live ɘvil Wrote:
> > George J Wrote:
> > So I removed the brake light bulb,wheni apply the brake lever she
> > doesn't stall. With the bulb in, she stalls when brake lever applied.
> > Front or rear. Diagnosing lectrical problems is not my strong point.
> Did you extract the blue wire from control pod on bars like I mentioned
> above^? If so, that would be the reason. The commuter is wired
> differently than most others. Put it back and tee into blue for
> grounding to bars to kill motor until you can repair kill switch.
I haven't yet but I'm going to do it now. The blue wire goes to the throttle side.Biu when i pull on either brake the motor cuts out.
  Can't shut her off.Topic by: George J George J 08/27/19 04:46PM
  Re: Can't shut her off.Re: Andrew Leone Andrew Leone 08/27/19 04:52PM
  Re: Can't shut her off.Re: live ɘvil live ɘvil 08/27/19 04:59PM
  Re: Can't shut her off.Re: George J George J 08/27/19 05:16PM
  Re: Can't shut her off.Re: live ɘvil live ɘvil 08/27/19 05:18PM
  Re: Can't shut her off.Re: George J George J 08/27/19 05:26PM
  Re: Can't shut her off.Re: George J George J 08/27/19 05:01PM
  Re: Can't shut her off.Re: Andrew Leone Andrew Leone 08/27/19 05:26PM
  Re: Can't shut her off.Re: live ɘvil live ɘvil 08/27/19 05:35PM
  Re: Can't shut her off.Re: Nick Haber Nick Haber 08/27/19 05:02PM
  Re: Can't shut her off.Re: George J George J 08/27/19 05:06PM
  Re: Can't shut her off.Re: Andrew Leone Andrew Leone 08/27/19 05:27PM
  Re: Can't shut her off.Re: George J George J 08/27/19 05:35PM
  Re: Can't shut her off.Re: Adam Smith Adam Smith 08/27/19 07:31PM
  Re: Can't shut her off.Re: K Olena K Olena 08/28/19 12:10PM
  Re: Can't shut her off.Re: Bad Cadillac™ Bad Cadillac™ 08/29/19 08:39AM
  Re: Can't shut her off.Re: live ɘvil live ɘvil 08/29/19 10:08PM
  Re: Can't shut her off.Re: George J George J 08/29/19 04:52PM
  Re: Can't shut her off.Re: George J George J 08/30/19 10:26AM
  Re: Can't shut her off.Re: live ɘvil live ɘvil 08/30/19 11:18AM
  Re: Can't shut her off.Re: George J George J 08/30/19 11:24AM
  Re: Can't shut her off.Re: live ɘvil live ɘvil 08/30/19 12:46PM
  Re: Can't shut her off.Re: George J George J 08/30/19 02:01PM
  Re: Can't shut her off.Re: live ɘvil live ɘvil 08/30/19 06:42PM
  Re: Can't shut her off.Re: George J George J 08/30/19 08:39PM
  Re: Can't shut her off.Re: live ɘvil live ɘvil 08/30/19 10:23PM
  Re: Can't shut her off.Re: live ɘvil live ɘvil 08/30/19 11:47PM
