Vespa Crank in Kinetic Case
Thomas TPRF /
What has to be changed over on the clutch side to get things to work?
I know it's been brought up but I've searched and can't find it.
The Vespa crank snout is shorter, the Kinetic clutch won't work. Either the pulley scrubs the subframe or you shim it out and the clutch plate won't engage.
