Tomos arrow r chain adjustment
I need some pics or possibly a brief detailed description on how to properly tighten the chain on my 2006 tomos arrow r thank you.
Re: Tomos arrow r chain adjustment
One should thoroughly clean and lube a drive chain first. It will most likely loosen up some more after doing so. Then adjust chain last.
Most bikes with the swingarm arc movement require you to adjust the chain a little loose when no weight is on the bike. When you hit a bump, the swingarm will tighten the chain and stress it and the sprockets and bearing of the front sprocket IF it's too tight. Leave at least 1/2" up and 1/2" down free movement while sitting on it.
start w a good chain n sprockets. old chain/sprockes cause looseness. anyways theres a couple nuts/bolts 17mm in the back of the swing arm, that allow for chain adjustment.
