Re: Tomos arrow r chain adjustment
Don Ohio /
Most bikes with the swingarm arc movement require you to adjust the chain a little loose when no weight is on the bike. When you hit a bump, the swingarm will tighten the chain and stress it and the sprockets and bearing of the front sprocket IF it's too tight. Leave at least 1/2" up and 1/2" down free movement while sitting on it.
