V1 no spark, bad ignition?
So I'm just trying to get spark...
I have a v1 on a gadabout, a blue red and black wire coming out of the ignition
I disconnected the black, blue is to a frame engine mount that I cleaned well. I'm positive it's a good ground
The red is going directly to the coil (new) paired with a new plug
I confirmed the points are opening and closing and I cleaned them as well...
Soldered in a new condenser
Bypassed the coil/plug with a test light to ground, still nothing
-____-
I'm stumped, and frustrated
Re: V1 no spark, bad ignition?
Richard Eberline /
condenser is soldered bad, slag pocket. Clean paint off for external coil, needs a good ground. Disconnect the kill switch, remove its ground wire. Test red wire's voltage, the coil is 12VAC. Pedal test around 4VAC. Report back
