Re: Solved previous problems, all was good, more arose
Drake Abrahamsson /
> ♣Slew Foot♣ Wrote:
> No no no I got this nailed check your exhaust make sure it ain't clogged
> your timing is off and the top is super cool and your pipe is cherry red
> you're lucky it didn't break off
I will check it, but the pipe is brand new, do you think it'd really be clogged? Timing is 16 deg and not skipping around like it was during the last discussion. I think I could diagnose this better if I understood how heat is pushed into the pipe. How does the cylinder/head stay cool while the pipe gets super hot? Thank you
