Re: Solved previous problems, all was good, more arose
Overpriced Parts /
> Drake Abrahamsson Wrote:
> > ♣Slew Foot♣ Wrote:
> > No no no I got this nailed check your exhaust make sure it ain't
> clogged
> > your timing is off and the top is super cool and your pipe is cherry
> red
> > you're lucky it didn't break off
> I will check it, but the pipe is brand new, do you think it'd really be
> clogged? Timing is 16 deg and not skipping around like it was during the
> last discussion. I think I could diagnose this better if I understood
> how heat is pushed into the pipe. How does the cylinder/head stay cool
> while the pipe gets super hot? Thank you
Think of it like this in away:
The pipe/chamber is the supercharger, the more advance timing the more boost
