Re: Peugeot 102 timing and possible Dellorto upgrade
Matt Doan /
Thanks for the suggestions guys! I might see if I can salvage the gurtner but failing that I’ll end up splurging on a 14.12 provided I can figure out a decent way to shim it up to the stock intake. I also looked in the owners manual and saw that the 102 has the same ignition timing of 1.5mm btdc as the 103.
Thanks again,
Matt
