Re: Peugeot 102 timing and possible Dellorto upgrade
Rebel Moby /
Shim is only to make up the difference between the OD of the intake and the ID of the carb clamp, you could even fabricate one from a beverage bottle or other plastic. For sealing at the union between carb and intake you can use a oring. 5/8 x 13/16 x 3/32 oring is a great fit into the 14mm bodied carb sizes
