2003 Kinetic TFR - No Lights
hey guys ... I have another question asked about engine but guess I will pull mine out to compare to 2006 model ..
Also non of the lights work .. the ignition key turns but no lights .. I know they have no battery, but where can I start to check for power ?
Re: 2003 Kinetic TFR - No Lights
You will only have lights while it is running. There is a yellow and a black wire coming out of the engine that plugs into the voltage regulator. You can follow the wiring from the voltage regulator and check for power from there. (edited)
