I agree with the idle jet. Do VMs have an air mixture screw? I forget. Dialing that in might help.
Also, here's a little clutch secret for you. Treatland has a performance clutch for V1's, but the pedal start is out of stock. You can buy the kick start clutch, drill out the rivets holding the KS gear on, and it works amazing for the pedal start engine.
