Re: Am I four-stroking? And what to do about it
> Rebel Moby Wrote:
> Based on the CR being the real compression ratio and not the swept
> compression ratio.
good point. generally I've found the mfgs stated CR to be the target number, which almost always differs from the calculated value.
also be sure to test on a warm engine, and crank with the throttle wide open.
