Derbi Flat Reed Exhaust port
shman shmilroy /
AY,
New to Derbis. Has this exhaust port on a '89 Variant Sport Flat reed been altered from stock? To my eye it looks like it may have been opened up a little the last 4-6mm from the external face of exhaust port into the exhaust duct ... I'm just not at all familiar with Derbs. <3.(edited)
Re: Derbi Flat Reed Exhaust port
shman shmilroy /
is it flatreed or flat reed? asking for future search key word .(edited)
I haven't seen a standard moped flange that looks like that, looks like it was altered for use with a slip flange with a conical joint? Kind of like some car exhaust joints? Or maybe a crush ring of some kind.
Dirty30 Dillon /
A ton of Derbi FR topends ran a cone header like that, from the factory. Just a standard cylinder.
That's interesting, I wonder what the header looked like
shman shmilroy /
I'll get a pic later.
Dirty30 Dillon /
> factory.
They had a loose flange, like hobbit exhaust, and the lip matched that cone shape
shman shmilroy /
yup.
I bet you could use a copper ring the seal it up with normal exhaust
shman shmilroy /
I'm at the point of exhaust reinstall, and I'm lost on how the gasket is supposed to fit on? D30, is that cone supposed to fit all the way flush into to the cylinder body? or is the cone supposed to act as a sort of tight seating angle eliminating the need for a gasket?
right now my cone is not flush.. ill clean it and smooth out any rough patches.
Dirty30 Dillon /
As far as I recall, it is meant to be a taper seal. I didn't have any gasket material in mine by the time I got it, but that def doesn't mean it wasn't supposed to be there.
