ZA50 drive gear. Is this Normal?
Rebuilding another ZA and don’t remember there being a space between the drive shaft and drive gear. Are these two piece?
Does this need to be pressed together?
Re: ZA50 drive gear. Is this Normal?
Wesley Ambrosini /
This is what mine looks like
Ugh. Looks like I have an issue. I like your extra groove for a snap ring to hold the sprocket.
Thanks for the pic.
So has anyone seen this gear/drive shaft apart? I assume it can be pressed back?
never seen that but i'd definitely just press it back, got access to a press?
Yup plan to. Thought Roff would wade in given his ZA experience.
Richard Eberline /
They made two styles or versions. Just on the sprocket side.
Yes I now get the differences on the end shaft at the sprocket. Wondering again about the gap that has opened up on the shaft where it connects to the gear. I thought this was all one piece.
Will try heat and a press this weekend to try and close the gap.
Thanks for the responses.
Maybe try a deep well socket and a hammer ? About 2 seconds worth of worry . ;)
Heat and a 12T press and it closed the gap.
The one I bought had the same problem and it's caused from running your drive chain too tight.
