Help me identify what the previous owner did to my moped?
First.... it works perfect, so I have no issues, I just know it isn't stock and seeing a condenser mounted on the frame I'm guessing it's an upgrade.
What am I looking at ?
Re: Help me identify what the previous owner did to my moped?
Coil and condenser mounted externally.
So that's the myrons fix?
Lights all work but at night I can't see shit.
It seems like the dc conversion and all the scary electrical talk makes a brighter bulb scarier
Mopedin is scary
> P D Wrote:
> Search . You'll find too many ideas . Here , I did a little for ya :
> https://mopedarmy.com/forums/search.php?6,search=headlight+halogen,author=,page=1,match_type=ALL,match_dates=0,match_forum=ALL,match_threads=0
Ha. I have read a ton of them. The dc floating ground stuff mixed with the two guys that always fight about their degrees and stuff... makes me think I'll just brake this pug.
I'll just try different bulbs
Fo Real! It gets old quick, don’t it! Childish pissing contest. At least we know who not to pay attention to.
Easy way to get bright lights is put a le partie cdi on it.
Depending on the size of your headlight ring/bucket you could try one of these:
http://www.amazon.com/dp/B07LBKCRSR/
I picked up 12v coils for a while off peoples no longer functioning cheapo treats CDI's. the pickups would burn out and people'd give away the broken stators with still good 12v coils. might try buysell ask
If this moped has a hi beam low beam off switch does that mean the bulb should be 6v 21w two filament or single?
Requires a double filament bulb for full function .
Single filament in now.... explains why it is so dim....
