Broken clamp bolt on my stock Peugeot 103 intake
Blasting around the hood yesterday and I started to bog.
I have just done a full carb clean and pipe refurb so I knew shit could vibrate loose.
I sprayed the intake with carb cleaner and the moped started to die...
Tightened the hex 10 bolt on the clamp and it twisted right off.
Was a bitch to get the end out... but some tin snips and wd40 and patience helped.
Here is what broke:
Here is the screw:
It didn't have a nut on it or anything. Am I good with hardware store parts?
Re: Broken clamp bolt on my stock Peugeot 103 intake
Should be OK with a standard grade bolt . You might consider stepping up a grade , just because you can .
I'll get the best I can for now.
Handy chart!
Got another bolt and nut (8.8)
Shredded both.
I guess I dont have the carb on the intake correct which doesn't matter as I'm about to put new reed intake and carb on..... whatever I'll look after I get it off...
> Shredded both.
I wouldn't think that bolt has to be that tight .
Yeah I'm with you PD... It may not be on the intake right..... I'll fuck with it on e it is off the engine
