Carb Rejet QT50
Louis Jacques /
I'm looking for a replacement jet for a Yamaha qt50. for a k and n universal air filter.
Re: Carb Rejet QT50
Have you ridden it with that filter? If that's a standard cone metal mesh filter sometimes they run fine without monkeying with the carb (if all is well with the carb.)
Re: Carb Rejet QT50
look up (or at) the carb, prolly mikuni vm12? and then search for jets for the carb type not by bike
Re: Carb Rejet QT50
Jack Rutherford /
you are probably fine with the stock jet but if you want more, do it!
