Well shit
up shits creek /
Took off flywheel of a mag I just picked up and the bolt holding the flywheel down fell off. Tried to start threads but it doesnt wanna go. Halp?!
Retap? New crank/bearings?!
Re: Well shit
Find the right size die and start it on there. Then a new nut the correct thread.
Re: Well shit
up shits creek /
> correct thread.
<~noob how do I find the right die size?
Re: Well shit
Should be a metric size and count the threads in one half inch. Take the old nut to the Ace Hardware or other and let them check it. Make sure you get someone that knows bolts and nuts.
A person needs a metric set of taps and dies in their garage, along with SAE ones too.
Re: Well shit
Or , you could clean the crank end up with a set of jewelers files .
It requires patience .
Then see about a proper nut .
A thread gauge would help .
Re: Well shit
Dirty30 Dillon /
100% should be able to use a file to clean than up
Re: Well shit
by the picture something weird going on. there are two sets of threads, the original coarse and a tiny bit of fine.
post your moped brand, most are m8 x 1.25. ignore those fine threads at the beginning there are plenty of og thread on crank.
id pop the fly wheel off, cut a m8x 1.25 nut in half, clean n clamp the two halves onto thread and back out
to clean. file as necessary. post results.
Re: Well shit
up shits creek /
79 puch magnum. The nut is toast. I have a new one. Just need to get the crank to thread. Currently just spins.
Re: Well shit
Go to the store and buy a 10x1.0 die!
Lowe’s sell them they are cheap like $10 bucks.
You should have plenty of thread still to grab
Re: Well shit
I've been unsuccessful finding a 10x1.0 tap or die other than special order. Nuts are hard to find as well. Bicycle stuff is that thread and was able to use some axle nuts for a flywheel nut.
Re: Well shit
ACE Hardwares have a good selection of metric nuts and bolts. As most of my petcocks are 10 x 1.0, I often take them there to verify size. The issue that could arise is if the needed nut is reverse threaded...
Re: Well shit
By the pic it is not reverse threads. I'm surprised that bicycle nuts would fit.(edited)
Re: Well shit
up shits creek /
Thanks for die size. Now let's see if I can find one.
Re: Well shit
Here ya go :
10 mm x 1.00 Metric Carbon Steel Hex Rethreading Die
Re: Well shit
Pushrod Fifty /
McMaster-Carr ships really fast. You can buy the die that you need and an M6-1 tap and die that you will need sooner or later for cleaning up stripped case threads and screw ends.
Re: Well shit
up shits creek /
> Here ya go :
Cool cool. Need to find a set since I don't have the other tool to drive it
Re: Well shit
> John Maxson Wrote:
> CrackMaster-Carr ships really fast. You can buy the die that you need and
Fixed the name for you, you cant just order a little bit, so much good stuff!
Re: Well shit
up shits creek /
https://tinyurl.com/refyjt5
got this set coming today. How do I make sure the threads i make on the top of that crank match the lower threads?
Re: Well shit
That looks like a nice set .
Matching threads is exactly why I keep a set of jewelers files on hand .
Work the threads from good to bad , until the bad are good .
Not to mention , files are a lot cheaper , take a lot less room and get the job done in the time it takes to order a burger . ;)
Re: Well shit
up shits creek /
Victory! What a pain in the ass. Had to tip bike on its side and use all my body weight. But it's done. Threads look good. Tapped the old bolt while I was at it too.
Thanks everyone for the deets
Re: Well shit
GREAT! Thanks for posting back results! Ridin time!
Re: Well shit
up shits creek /
Brap brap
Re: Well shit
Fuck yea dawg! Just remember if anyone asks Rocco helped
