Re: No power - Vespa Piaggio SI
Kristian Lomeland /
> Ike Pipe Wrote:
> It looks like there is some binding in the drive train. If you're on the
> stand and you give it a tiny bit of gas, your wheel should spin. In
> fact, it should spin a little bit at idle. Unless your wheel is touching
> the ground? I couldn't tell.
> Jetting may be off. I've seen that setup with jetting as low as 58, and
> as high as 65. No power when running seems like a lean condition. I'd
> suggest you try up jetting just to see what you get.
> Your electrical is fine, I think. Running reliably as it did with a good
> idle and no backfires, if it were me, I'd rule that out for now.
Yeah, I am holding the tire to the ground in the video. When on the stand with wheel in the air, it spins a bit at idle. Its when it must pull anything it just has nothing.
I can try to upjet, and report back. I have a full range of 60s.
