Re: No power - Vespa Piaggio SI
Kristian Lomeland /
> Dirty30 Dillon Wrote:
> Looks like your belt is not adjust correctly and the belt's spinning on
> the rear cheeks.
The rear cheeks are spinning, but the clutch housing i shaking like crazy.
> Ike Pipe Wrote:
> If the upjet doesn't work, I'd revisit the leak down. What method did
> you use?
Okay. I plugged up exhaust and intake. Then i screw in a custom air coupling that i’ve welded to correct thread to go in the spark plug hole. Then i hook up the air and have 4 bar on the dial. Then i go over hearing and using soapy water to check for leaks.
> pat splat Wrote:
> i hear a clickity clickity sound, kinda like a sloppy piston or needle
> bearings in the rear pully or... take off the belt and feel for
> rubbing/smoothness.
Yes, I hear it too. I have no idea where it comes from. There is a new piston and rings in it.
Does the pulley have bearings also? It feels smooth and easy when turning it by hand.
The belt gets wounded a bit, but cant feel any issues with either front- or rear variator smoothness
