Carberator
Michael simmons /
Why does my 1979 pa50 only run with the choke on. When I cut the choke off it dies
Re: Carberator
Clean the carb .
Re: Carberator
Air leak. Choke makes it run rich (more fuel.) With the choke off, it's getting air from somewhere else.
When it's running, spray carb cleaner around all the connections, carb to manifold, manifold to engine, etc.
If it revs up or sputters where you sprayed it, there's your leak.
Re: Carberator
b4 u extract carb. take off that little silver flathead and blast it with brake cleaner/compressed air, do the same with the air mixture screw. now that air mixture screw is something like 3 1/2 turns out as well.
Re: Carberator
OR a partially clogged passage in carb needs choke to pull the fuel thru.
Re: Carberator
♣Slew Foot♣ /
Check fuel flow with cap on if your fuellinee is restricted it will do that....
Re: Carberator
> P D Wrote:
> Clean the carb .
^^^^^ what he said
Re: Carberator
A common cause is the pilot jet in the carb is blocked.
