yamaha vino50
kenneth lathers /
after cleaning carb. how can I be sure oil line is inserted correctly and working. seems it slides in hole on carb?
Re: yamaha vino50
there's no oil line on a vino 50 carb. you can find carb rebuild videos on youtube and follow where the lines all go. the fuel line in, the air/vacuum line to the petcock are the only ones really critical. the tubes off the bottom are just to drain the bowl and the one off the side is a vent
Re: yamaha vino50
kenneth lathers /
heres the line coming out of the motor beneath the carb
