Suzuki FA50 fuel cock
My Suzuki FA50 runs good with the fuel cock on "prime". When I put it on "run" it does ok for a while then stalls. I pulled the vacuum hose and sucked on it and fuel flowed on the fuel line. That tells me the fuel cock is working properly. Can I just run with it on prime? Would that cause any problems while running? Any suggestions?
Re: Suzuki FA50 fuel cock
Your sucking is more powerful than the suction of the intake .
I would take the petcock apart and clean it . It may have crud built up inside .
Be sure the vacuum tube fits snug on both ends .
It will run fine on Prime .
I would switch it to On when not ridden , like over night .
Ok thanks. That all makes sense. I was concerned that running on prime would flood the carb. I undstand turning it back to run when parked.
