Judge my sha 15.15 airfilter hack
It is made if the thickest screen in the stock filter and then a piece of pan scrubbing mesh.
Stock slide and main jet.
It's pretty good off the line and tops out at 34 mph on flat land.
Definitely goes up hills stronger than the stock set up. And I haven't pulled balls from variator
Re: Judge my sha 15.15 airfilter hack
Did you oil the screen and scub pad?
It looks like a robot's pubes.
Can only ride on dry days.
Lmfao! :D But as mentioned may be a issue in the wet...
If you ride in the wetness, you can use it to scrub your bike clean when your done.
Hahahaha
I live in LA so it is NEVER wet.
Dirty30 Dillon /
It's looks as bad as it filters air.
Just get you a k&n or uni filter offline. And your in California you say?? Duddde!! That area has a dozen motorcycle shops!!
We find you guilty of molesting air filtration systems.
And guilty of exposing robotic pubes.
Your sentencing will be excessive cylinder wear and scoring due to foreign particulates passing through robotic pubes into the engine causing additional friction and scoring damage and hard seizure of piston and cylinder.
And you are hereby ordered to pay $100 in court fees to the local moped gang in your area.
Case closed
Dirty30 Dillon /
You don't say. California has a dozen Moto shops...
