Garelli VIP won’t kick start
August Adams-Miller /
Ped is a 1980 Garelli VIP 2 speed. I have a MLM exhaust on it. I’ve never been able to start this ped without furiously pedaling down a hill on the stand. When I pull the clutch in to kick start there’s not a strong resistance on the pedals like other mopeds. Once it starts it runs and idles great. Any idea why it won’t kickstart?
Re: Garelli VIP won’t kick start
When u grab the starter lever and the motor spins over the compression is not really felt too much because of the vip being a two speed, making it fairly easy to pedal.
afa starting, a tune up should get u to not pedal like mad. hows the mlm?
I love the MLM, worth every penny imo. Top speed is around 35 on flat now.
> now.
I was doing 38 with one of these
https://www.doscycles.com/products/garelli-vip-nero-2-exhaust
And a phbg 19 carb and intake. I wonder how fast it would be with a carb and intake?
Maybe low compression .
How many pounds compression does the motor have ?
How can I check this? I have no idea how many lbs of compression.
You need a compression tester .
Remove the spark plug .
Insert the tester .
Quickly rotate the motor numerous times , with the throttle wide open .
Read gauge .
Report here .
