Fuel into bowl not fast enough
I drink all my bowl at WOT.
I cleaned the inlet and carb. Just doesnt flow fast enough
Re: Fuel into bowl not fast enough
Clean the petcock
Petcock is clean. It seems restricted at the bowl valve. 15mm Bing btw
Hss to be the float.set wrong.or the passage clogged then ..not much else it could be
♣Slew Foot♣ /
Gas cap vent. Bigger dia line. Shorter length hi flow filter.
It doesnt help my intake sit at a 45 degree.
Overpriced Parts /
You just answered your question, make it sit more flatter
Yeah the flow isnt really there. Im gonna have to make an intake. My intake broke so i cut it and theres no way to make it sit any flatter without jankass tubing
Simply , don't run it a WOT .
Problem solved . ;)
Richard Eberline /
mock it up, then weld. I will weld it.
♣Slew Foot♣ /
505 1a.
I have an intake...
80cc Athena. 15mm Bing. Want a VM18.
well there's your problem, that thing's at like a 60° angle
Lol. Yeah. Goes great until she goes dry....
Richard Eberline /
That set up will seize your cylinder/piston. High RPM's then run dry, that is toasty.
Mmmmm,mmmm, toasted.
Thanks for the advice.
It has a 16in rim with 46 tooth. Really makes it rev high too.
Also need dextron.
